Hi Everyone,
We are trying to integrate ShinyProxy with OpenID. We have managed to authenticate and obtain an ID token, but we are facing issues with sending a correct userinfo request and are not receiving the necessary claims.
We followed the documentation and used the following configuration, but the flow is not working as expected:
authentication: openid
openid:
auth-url: https://domain/auth/realms/xxxx/protocol/openid-connect/auth
token-url: https://domain/auth/realms/xxxx/protocol/openid-connect/token
jwks-url: https://domain/auth/realms/xxxx/protocol/openid-connect/token
userinfo-url: https://domain/auth/realms/xxxx/protocol/openid-connect/userinfo
jwks-signature-algorithm: "PS256"
client-id: "xxxx"
client-secret: "xxxxx"
username-attribute: sub
scopes:
- profiles
- email
- offline_access
openid-scopes:
- profile
- email
- offline_access
role-claim: email
groups-claim: profiles
# Example container app
container-log-path: /opt/shinyproxy/container-logs
- id: MAPAS
display-name: APP MAPAS
description: APP MAPAS
container-image: image-....
container-env:
SUB: "#{oidcUser.attributes['sub']}"
ID_TOKEN: "#{oidcUser.idToken.tokenValue}"
EMAIL: "#{oidcUser.attributes['email']}"
PROFILE: "#{oidcUser.attributes['profile']}"
PROFILES: "#{oidcUser.attributes['profiles']}"
The authentication flow seems to work fine. We enter the credentials and receive the ID token, but the userinfo request is not triggered as expected. We are not getting the required claims that are not in the id token.
As a result, we see the landing page after login without errors, but when we try to access the app, we encounter the following error:
eu.openanalytics.containerproxy.ProxyFailedToStartException: Container failed to start
at eu.openanalytics.containerproxy.service.ProxyService.prepareProxyForStart(ProxyService.java:458) ~[containerproxy-1.1.1.jar!/:1.1.1]
at eu.openanalytics.containerproxy.service.ProxyService.startOrResumeProxy(ProxyService.java:466) ~[containerproxy-1.1.1.jar!/:1.1.1]
at eu.openanalytics.containerproxy.service.ProxyService.lambda$startProxy$5(ProxyService.java:293) ~[containerproxy-1.1.1.jar!/:1.1.1]
at eu.openanalytics.containerproxy.service.ProxyService.lambda$action$12(ProxyService.java:638) ~[containerproxy-1.1.1.jar!/:1.1.1]
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[na:na]
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) ~[na:na]
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1135) ~[na:na]
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[na:na]
at java.base/java.lang.Thread.run(Thread.java:831) ~[na:na]
Caused by: eu.openanalytics.containerproxy.spec.expression.SpelException: Error while resolving expression: "#{oidcUser.accessTokenAsJwt.claims}", error: EL1021E: A problem occurred whilst attempting to access the property 'accessTokenAsJwt': 'Unable to access property 'accessTokenAsJwt' through getter method'
at eu.openanalytics.containerproxy.spec.expression.SpecExpressionResolver.evaluate(SpecExpressionResolver.java:111) ~[containerproxy-1.1.1.jar!/:1.1.1]
at eu.openanalytics.containerproxy.spec.expression.SpecExpressionResolver.evaluateToString(SpecExpressionResolver.java:119) ~[containerproxy-1.1.1.jar!/:1.1.1]
at eu.openanalytics.containerproxy.spec.expression.SpelField$StringMap.lambda$resolve$0(SpelField.java:328) ~[containerproxy-1.1.1.jar!/:1.1.1]
at java.base/java.util.LinkedHashMap.forEach(LinkedHashMap.java:723) ~[na:na]
at eu.openanalytics.containerproxy.spec.expression.SpelField$StringMap.resolve(SpelField.java:328) ~[containerproxy-1.1.1.jar!/:1.1.1]
at eu.openanalytics.containerproxy.model.spec.ContainerSpec.finalResolve(ContainerSpec.java:142) ~[containerproxy-1.1.1.jar!/:1.1.1]
at eu.openanalytics.containerproxy.model.spec.ProxySpec.lambda$finalResolve$3(ProxySpec.java:157) ~[containerproxy-1.1.1.jar!/:1.1.1]
at java.base/java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:197) ~[na:na]
at java.base/java.util.AbstractList$RandomAccessSpliterator.forEachRemaining(AbstractList.java:720) ~[na:na]
at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484) ~[na:na]
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474) ~[na:na]
at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:550) ~[na:na]
at java.base/java.util.stream.AbstractPipeline.evaluateToArrayNode(AbstractPipeline.java:260) ~[na:na]
at java.base/java.util.stream.ReferencePipeline.toArray(ReferencePipeline.java:616) ~[na:na]
at java.base/java.util.stream.ReferencePipeline.toArray(ReferencePipeline.java:622) ~[na:na]
at java.base/java.util.stream.ReferencePipeline.toList(ReferencePipeline.java:627) ~[na:na]
at eu.openanalytics.containerproxy.model.spec.ProxySpec.finalResolve(ProxySpec.java:158) ~[containerproxy-1.1.1.jar!/:1.1.1]
at eu.openanalytics.containerproxy.service.ProxyService.prepareProxyForStart(ProxyService.java:451) ~[containerproxy-1.1.1.jar!/:1.1.1]
... 8 common frames omitted
We would appreciate it if you could tell us what might be missing or incorrect in our configuration.
