User shinyprox takes whole cpu from ./kswapd0 process
As from the title, this process from shinyproxy takes the whole CPU, freezing the server. The only solution I found is to kill the process, which restarts randomly from hours to a few days later.
immagine
NOTE: I even tried to turn off the docker instance of shinyproxy, but that didn’t change anything, and the issue persists. I do not understand how that was possible.
Do you have some ideas to find the root cause of that, and possibly solve it?
Thank you!!
Corrado.
systeminfo:
java -version
openjdk version “11.0.17” 2022-10-18
OpenJDK Runtime Environment (build 11.0.17+8-post-Ubuntu-1ubuntu218.04)
OpenJDK 64-Bit Server VM (build 11.0.17+8-post-Ubuntu-1ubuntu218.04, mixed mode, sharing)
cat Dockerfile
FROM openjdk:11-jre
RUN mkdir -p /opt/shinyproxy/
RUN wget https://www.shinyproxy.io/downloads/shinyproxy-2.4.3.jar -O /opt/shinyproxy/shinyproxy.jar
COPY logo.png /opt/shinyproxy/logo.png
WORKDIR /opt/shinyproxy/
CMD [“java”, “-jar”, “/opt/shinyproxy/shinyproxy.jar”]
cat application.yaml
title: Unit of Biostatistics, Epidemiology, and Public Health’s Shiny Proxy - University of Padova
logo-url: file:///opt/shinyproxy/logo.png
container-log-path: ./logs/container-logs
heartbeat-timeout: 60000
admin-groups: admins
  • name: XXXXXXX
    password: XXXXXXX
    groups: XXXXXXX
  • name: XXXXXXX
    password: XXXXXXX
    groups: XXXXXXX
  • name: XXXXXXX
    password: XXXXXXX
    groups: XXXXXXX
    container-network: sp-ubep-net
  • id: covid19ita-devel
    display-name: CoViD19ita Development
    description: Examples and experiments for the covid19ita Shiny app
    container-cmd: [“R”, “-e”, “options(‘shiny.port’=3838,shiny.host=‘0.0.0.0’);covid19ita.devel::run_app()”]
    container-image: covid19ita-devel
    access-groups: [ubep, admins]
    container-volumes: [“/srv/azero-data:/volume”]
    container-network: “${proxy.docker.container-network}”
  • id: susy3dpp
    display-name: SusySafe 3D-Enhanced Registry
    description: Application to explore the 3D-enhanced version of the SusySafe registry
    container-cmd: [“R”, “-e”, “options(‘shiny.port’=3838,shiny.host=‘0.0.0.0’);susy3dapp::run_app()”]
    container-image: susy3dapp
    access-groups: [ubep, admins, zeta]
support:
mail-to-address: XXXXXXX
mail-from-address: XXXXXXX
spring:
mail:
host: smtp.gmail.com
# TLS: 587 SSL: 465 Plain: 25
port: 465
username: XXXXXXX
password: XXXXXXX
properties:
# For StartTLS
#mail.smtp.starttls.enable: true
# For SSL
mail.smtp.socketFactory.class: javax.net.ssl.SSLSocketFactory
useForwardHeader: false
servlet:
context-path: /sp
file: /logs/shinyproxy.log
