Thanks for the hard work on Shinyproxy. I was one of many that are happy with the newest release with the web service authentication support. While setting up the web service auth, I ran into a problem-- the web service that I am using is based on SOAP (ver. 1.1 I guess) that only allows XML. Based on your document in the Shinyproxy website:
authentication-url: https://your-auth-server.com/login
authentication-request-body: “{username: %s, password: %s}”
It seems the request body allows JSON body. Is there a way to work around for XML based POST? Thank you!!
