X-Forwarded-Proto overwritten to http when using an external Reverse Proxy (NGINX)
I am running ShinyProxy via the ShinyProxy Operator (v2.3.1 / v3.2.2) behind an external NGINX reverse proxy that handles SSL/TLS. Although NGINX is correctly configured to send X-Forwarded-Proto: $scheme (also tried forcing to https), at some point Caddy (I think) changes to HTTP.
This causes internal redirects (like /login) to be generated with the http:// scheme. The main problem is caused when logging in, which leads to shinyproxy.mydomain/auth-success. Then, via JavaScript, a redirection to the landing page (/) is attempted, but as it’s done from an HTTP page, the server causes a SecurityError and aborts the redirection:
Uncaught SecurityError: Failed to execute 'pushState' on 'History': A history state object
with URL 'http://shinyproxy.mydomain/' cannot be created in a document
with origin 'https://shinyproxy.mydomain' and URL 'https://shinyproxy.mydomain/auth-success'.
I’ve configured NGINX as stated in https://www.shinyproxy.io/documentation/security/#https-ssl–tls to redirect to localhost:8082 (operator port changed with #77, working well), with all headers:
server {
    server_name shinyproxy.mydomain;
    location / {
        proxy_pass http://localhost:8082;
        proxy_http_version 1.1;
        proxy_set_header Connection 'upgrade';
        proxy_set_header Host $host;
        proxy_set_header X-Forwarded-Proto https;
        proxy_cache_bypass $http_upgrade;
    listen 443 ssl; # managed by Certbot
    ssl_certificate /etc/letsencrypt/live/mydomain/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/mydomain/privkey.pem; # managed by Certbot
    include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
    ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
    if ($host = shinyproxy.mydomain) {
        return 301 https://$host$request_uri;
    } # managed by Certbot
    listen 80;
    return 404; # managed by Certbot
In shinyproxy.yml I have server.forward-headers-strategy: native (also tried framework) and proxy.openid.enforce-https-redirect-uri: true. Also tried all troubleshooting steps in https://www.shinyproxy.io/documentation/troubleshooting/#invalid-redirect_uri:
spring:
  session:
    store-type: redis
image: openanalytics/shinyproxy:3.2.2
fqdn: shinyproxy.mydomain
  store-mode: Redis
  stop-proxies-on-shutdown: false
  title: My apps
  realm-id: shinyrealm
  authentication: openid
  openid:
I’ve got this with logging.requestdump: true just by loading shinyproxy.mydomain in a browser (before login or any other process).
----------------------------REQUEST---------------------------
               URI=/
 characterEncoding=null
     contentLength=-1
       contentType=null
            cookie=SESSION=NTQ5Z...........
            header=X-Real-Ip=myIP
            header=Accept-Encoding=gzip, deflate, br, zstd
            header=Dnt=1
            header=Sec-Ch-Ua=\"Microsoft Edge\";v=\"143\", \"Chromium\";v=\"143\", \"Not A(Brand\";v=\"24\"
            header=Sec-Fetch-User=?1
            header=Sec-Fetch-Site=none
            header=X-Forwarded-For=172.23.0.1
            header=Cookie=SESSION=NTQ5Z...........
            header=Host=shinyproxy.mydomain
            header=X-Forwarded-Host=shinyproxy.mydomain
            header=Accept=text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7
            header=Accept-Language=es,es-ES;q=0.9,en;q=0.8,en-GB;q=0.7,en-US;q=0.6
            header=Sec-Fetch-Mode=navigate
            header=User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/143.0.0.0 Safari/537.36 Edg/143.0.0.0
            header=Sec-Ch-Ua-Mobile=?0
            header=Sec-Fetch-Dest=document
            header=X-Forwarded-Proto=http
            header=Sec-Ch-Ua-Platform=\"Windows\"
            header=Upgrade-Insecure-Requests=1
            locale=[es, es_ES, en, en_GB, en_US]
            method=GET
          protocol=HTTP/1.1
       queryString=
        remoteAddr=/172.23.0.11:49858
        remoteHost=sp-caddy.sp-shared-network
            scheme=http
              host=shinyproxy.mydomain
        serverPort=8080
          isSecure=false
--------------------------RESPONSE--------------------------
     contentLength=0
       contentType=null
            header=Expires=0
            header=Cache-Control=no-cache, no-store, max-age=0, must-revalidate
            header=X-XSS-Protection=0
            header=Pragma=no-cache
            header=Location=http://shinyproxy.mydomain/login
            header=Date=Thu, 15 Jan 2026 15:50:43 GMT
            header=Connection=keep-alive
            header=X-Content-Type-Options=nosniff
            header=Content-Length=0
            status=302
               URI=/login
     contentLength=-1
       contentType=null
            header=Dnt=1
            method=GET
          protocol=HTTP/1.1
       queryString=
        remoteAddr=sp-caddy.sp-shared-network/172.23.0.11:49858
            scheme=http
        serverPort=8080
          isSecure=false
     contentLength=0
       contentType=null
            header=Expires=0
            header=Location=http://shinyproxy.mydomain/oauth2/authorization/shinyproxy
            header=Content-Language=es-
            status=302
               URI=/oauth2/authorization/shinyproxy
     contentLength=-1
       contentType=null
            header=Dnt=1
            method=GET
          protocol=HTTP/1.1
       queryString=
            scheme=http
        serverPort=8080
          isSecure=false
     contentLength=0
       contentType=null
            header=Expires=0
            header=Location=https://auth.mydomain/auth/realms/shinyproxy/protocol/openid-connect/auth?response_type=code&client_id=shinyproxy-client&scope=openid%20email&state=_usGfwMe2vIClaN6CPw_kcbPAkhegtCWHRahaH9HMhY%3D&redirect_uri=https://shinyproxy.mydomain/login/oauth2/code/shinyproxy&nonce=DMDeMwszeIh5pNFgsN0r3rBnnExQhzD5UQr5imnN6TA
            status=302
It appears that the internal Caddy instance managed by the Operator is receiving the request from NGINX and, since it’s receiving it on its HTTP port (8082), it overwrites the X-Forwarded-Proto header to http before passing it to the ShinyProxy JAR. Thanks for the help!
EDIT (2.03.): SOLVED. For me the solution was an overlook on the helm chart. The Default helmchart values.yml use shinyproxy.proxy.landingpage as a key. The corresponding template shinyproxy instance uses landing-page. Therefore there is a missmatch. Specifiying the key-value as landingpage leads to a landing-page null value in my application.yml.
I had to specify ‘shinyproxy.proxy.landing-page: “/” ’ in my values.yml to make it work.
I have the same problem.
Running operator version: 2.3.1 and shinyproxy 3.2.3 in an openshift cluster. Reverse Proxy is openshift default. Deployment via Helmchart of devxy/helm-shinyproxy: Helm chart for ShinyProxy - https://www.shinyproxy.io/ - CodeFloe - A code hosting platform for the modern age
I tried different fixes. None work. Interesting is though the default application.yml works. Something goes wrong when applying customizations.
  • I tried none, simple authenitication and OIDC via Keycloak
  • I tried different overwrites via SPRING_APPLICATION_JSON: forward-headers-strategy (like you), “tomcat”:{“use-relative-redirects”:true, “remoteip”:{“internal-proxies”:“.*”}}, “secure-cookies”:true
    •   - name: SPRING_APPLICATION_JSON
          value: '{"server":{
            "secure-cookies":true,
            "forward-headers-strategy":"native",
            "frame-options": "sameorigin",
            "same-site-cookie": "lax",
            "tomcat":{
              "use-relative-redirects":true,
              "remoteip":{"internal-proxies":".\*"}}}}'
  • I tried fixing shinyproxy.kubernetesIngressPatches to patch the operator default ingress behavior with https edge termination.
    kubernetesIngressPatches: |
    - op: add
    path: /spec/tls
    value:
    hosts:
    your.route.com
    secretName: your-cert-secret
    - op: add
    path: /spec/ingressClassName
    value: openshift-default
    # Add OpenShift HAProxy HTTP → HTTPS Redirect
    - op: add
    path: /metadata/annotations/route.openshift.io~1insecure-edge-termination-policy
    value: “Redirect”
It seems that between the default application.yml and a customized application.yml by helm, so parameters trigger the problematic redirect.
If you run into a solution, I am very interested.
