Mix ldap authentication with simple authorization
Thank you for the ShinyProxy
and I wanted to know if I can mix mix ldap authentication with simple authorization
as the example below:
  authentication: ldap
  admin-groups: admin
  - name: admin
    groups: admin
  ldap:
    url: ldap://ldap.forumsys.com:389/dc=example,dc=com
    user-dn-pattern: uid={0}
    group-search-base:
    group-search-filter: (uniqueMember={0})
    manager-dn: cn=read-only-admin,dc=example,dc=com
    manager-password: password
  # Docker configuration
  - id: 01_hello
    access-groups: [admin]
Thanks,
saif
Hello Saif,
Did you try your example and did it work? From the documentation I am under the impression it is impossible to mix authentications.
I have exactly the same need. Did you find a workaround?
I think I will try something based on this discussion:
