I read the comments of this topic (A proxy for RStudio Server like ShinyProxy) - it didn’t help.
I will try to describe my situation:
System:
Windows + WSL2 + Ubuntu 20.04 + Docker Desktop (Expose daemon on tcp: // localhost: 2375 without TLS -> ON)
What has been done and is working:
Created the /opt/R folder
Rstudio
Created the /opt/R/rstudio folder
Dockerfile for rstudio:
FROM rocker/rstudio RUN install2.r --error --skipinstalled \ renv RUN echo "www-frame-origin=same" >> /etc/rstudio/disable_auth_rserver.confNow if I write the commands:
docker build -t rstudio .
and
docker run --rm -p 127.0.0.1:8787:8787 -e DISABLE_AUTH = true rstudioThen the server (itself, without shinyproxy) starts up!
ShinyProxy
Created a folder /opt/R/shiny-proxy
Dockerfile for shinyproxy
FROM openjdk:11-jre RUN mkdir -pv /opt/R/shiny-proxy RUN cd /opt/R/shiny-proxy && wget https://www.shinyproxy.io/downloads/shinyproxy-2.5.0.jar EXPOSE 8080 WORKDIR /opt/R/shiny-proxy CMD ["java", "-noverify", "-jar", "shinyproxy-2.5.0.jar", "--spring.jmx.enabled=false", "--spring.config.location=./config/application.yml"]Docker-compose (in /opt/R)
version: '2' services: shiny-proxy: build: context: ./shiny-proxy/ image: shiny-proxy container_name: shiny-proxy-1 restart: on-failure environment: R_USER_PASSWORD: pass volumes: - /var/run/docker.sock:/var/run/docker.sock - ./shiny-proxy/config:/opt/R/shiny-proxy/config ports: - "8080:3838"And I fill in the application.yml file
server: forward-headers-strategy: native proxy: title: "Analyst module" template-path: ./templates landing-page: / heartbeat-rate: 10000 heartbeat-timeout: 60000 port: 3838 authentication: simple container-wait-time: 30000 docker: internal-networking: true admin-groups: admin users: - name: ruser password: pwd groups: admin specs: - id: "SEPARATOR_DEV" display-name: "Develop" logo-url: "code" - id: "rstudio" access-groups: [admin] display-name: "RStudio IDE" logo-url: "r project" description: "RStudio" container-image: rstudio port: 8787 container-volumes: [ "/home/#{proxy.userId}:/home/#{proxy.userId}" ] container-env: USER: "#{proxy.userId}" DISABLE_AUTH: true WWW_ROOT_PATH: "#{proxySpec.containerSpecs[0].env.get('SHINYPROXY_PUBLIC_PATH')}"ShinyProxy has started successfully!
But RStudio doesn’t want to run in it!!!
shiny-proxy-1 | 2021-09-12 14:38:43.265 WARN 1 --- [ XNIO-1 task-2] e.o.shinyproxy.ShinyProxyTestStrategy : Container unresponsive, trying again (2/15): http://7428710c6983:8787 shiny-proxy-1 | 2021-09-12 14:38:45.267 WARN 1 --- [ XNIO-1 task-2] e.o.shinyproxy.ShinyProxyTestStrategy : Container unresponsive, trying again (3/15): http://7428710c6983:8787 shiny-proxy-1 | 2021-09-12 14:38:47.268 WARN 1 --- [ XNIO-1 task-2] e.o.shinyproxy.ShinyProxyTestStrategy : Container unresponsive, trying again (4/15): http://7428710c6983:8787 shiny-proxy-1 | 2021-09-12 14:38:49.269 WARN 1 --- [ XNIO-1 task-2] e.o.shinyproxy.ShinyProxyTestStrategy : Container unresponsive, trying again (5/15): http://7428710c6983:8787 shiny-proxy-1 | 2021-09-12 14:39:01.282 WARN 1 --- [ XNIO-1 task-2] e.o.shinyproxy.ShinyProxyTestStrategy : Container unresponsive, trying again (6/15): http://7428710c6983:8787 shiny-proxy-1 | 2021-09-12 14:39:03.283 WARN 1 --- [ XNIO-1 task-2] e.o.shinyproxy.ShinyProxyTestStrategy : Container unresponsive, trying again (7/15): http://7428710c6983:8787 shiny-proxy-1 | 2021-09-12 14:39:05.285 WARN 1 --- [ XNIO-1 task-2] e.o.shinyproxy.ShinyProxyTestStrategy : Container unresponsive, trying again (8/15): http://7428710c6983:8787 shiny-proxy-1 | 2021-09-12 14:39:07.286 WARN 1 --- [ XNIO-1 task-2] e.o.shinyproxy.ShinyProxyTestStrategy : Container unresponsive, trying again (9/15): http://7428710c6983:8787 shiny-proxy-1 | 2021-09-12 14:39:09.287 WARN 1 --- [ XNIO-1 task-2] e.o.shinyproxy.ShinyProxyTestStrategy : Container unresponsive, trying again (10/15): http://7428710c6983:8787Question: What do I need to write to make it work?
