The dreaded failed to start
strikes again.
- All on internal net, using 192.168.2.20 et al. instead of localhost everywhere as suggested in many threads
- Simple authentication (not shown here) works, even when keycloak is installed but not used
- Keycloak good
- Logging in to Shinyproxy with keycloak works
- Clicking on
Hello Application
gives error:
**Status code:** 500
**Message:** Failed to start container
**Stack Trace:**
eu.openanalytics.containerproxy.ContainerProxyException: Failed to start container
Caused by: java.lang.IllegalArgumentException: second is marked non-null but is null
docker-compose.yml:
version: '3.8'
services:
# shinyproxy
shinyproxy:
build:
context: .
image: shinyproxy-example
container_name: shinyproxy-ex
ports:
- '8020:8080'
group_add:
- 1001 # docker cannot be used here in version 3+
networks:
- sp-net
volumes:
- /var/run/docker.sock:/var/run/docker.sock:ro
# Keycloak
keycloak:
image: jboss/keycloak
container_name: keycloak
ports:
- 8010:8080
networks:
- sp-net
volumes:
# Make this writeable for group docker
# do not use ~
- /home/dieter/keycloak/data/:/opt/jboss/keycloak/standalone/data/
environment:
# Only on first run
# https://stackoverflow.com/a/61071811
# - KEYCLOAK_USER=admin
# - KEYCLOAK_PASSWORD=admin
- PROXY_ADDRESS_FORWARDING=true
- TZ=Europe/Berlin
networks:
sp-net:
application.yml
title: Anomanor Shiny proxy
logo-url: https://menne-biomed.de/images/mennebiomed48.gif
authentication: keycloak
admin-groups: admins
keycloak:
realm: anomanor
auth-server-url: http://192.168.2.20:8010/auth
resource: anomanor
credentials-secret: 3f944ef7-2d15-481b-acc3-c5df3adc522a
- id: 01_hello
container-network: sp-net
- id: 06_tabsets
Note: Keykloak login IS rejects wrong logins, but these are not forwarded to Shinyprox, it always says User logged in [user: null]
, and the top right display of user name is empty.
