ShinyProxy on Fedora 34
I noted that a similar question from a few years ago (Shinyproxy-demo in Fedora 29 doesn't work) but without any discussion so I’ll add this.
I have installed docker and installed shiny proxy (2.5.0) from the rpm that is available from shinyproxy.io on Fedora 34. I have enabled these services and modified the docker service with the override.conf file in system.d as described in the getting started section of the documentation. However, as was previously mentioned in the post I mention above, when I visit the webpage localhost:8080 I get no response.
The reason this didn’t work was the default firewall configuration on Fedora doesn’t expose port 8080. To open the port and get this working first determine the default zone name of firewalld:
firewall-cmd --get-default-zone
Mine was “FedoraServer”. Then you can open port 8080:
firewall-cmd --zone=FedoraServer --add-port=8080/tcp --permenent
